Frequent Contributor II
I have strange issue with Clearpass captive portal ?
I have Self Register Captive Portal on Clearpass guest now when guest connect to guest ssid and wait around 2 to 3 minutues without entering credentials he disconnected automatically ..is there is a reason for this?
Super Contributor I
Re: I have strange issue with Clearpass captive portal ?
What type of client device is connecting to the captive portal? Are you also seeing the client device drop from the user table on the controller?
-Mike
Android devices, that have this issue actually
Super Contributor I
Within the Android family, is it devices that are older than Android 4? I've had a lot of success with Android 4.3, 4.4, and the new 5.0.
Thanks!
-Mike
thanks for replay I tested this issue on 4.2 and 4.3 and it happen on both
Depending on your controller settings the client will automatically get kicked off the network if they do not authenticate with a username and password.
Thank You,
Troy
What settings would do so.. can you please Specify ?
