before doing this test connect to the network
could it be that the dns server is not working..
try open a command prompt
you open it doing this:
you click on the windows symbol down at the left on search programs and files bar type this: cmd
it will open you a black window.
On the black window type
ping www.google.com and then press enter
if it does not resolve it willl never redirect you to the secure login... if it does resolve you willl get something liek this
C:\Users\c.testlocal>ping www.google.com
Pinging www.l.google.com [74.125.227.50] with 32 bytes of data:
Reply from 74.125.227.50: bytes=32 time=186ms TTL=53
Reply from 74.125.227.50: bytes=32 time=164ms TTL=53
Ping statistics for 74.125.227.50:
correct if im wrong collin
I think that could be the issue...
Or maybe you not getting an ip address
On the same black console type this
ipconfig /all
paste the output here..
