Regular Contributor I
IAP Clearpass problems with captive portal authentication
Hi@ all,
I´ve installed a brand new Clearpass Server version 6.6.0.81015 and I use this site to configure the IAP and the clearpass.
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/How-to-integrate-IAP-with-CPPM-to-perform-Captive-Portal/ta-p/187920
As Service Template I´ve uses Guest Access like in this dokument.
But the user cannot login to the capive portal, in the access tracker, I can see that no service matched for this authentication but the ssid is right.
Please take a look to the attached pics.
Leon
Re: IAP Clearpass problems with captive portal authentication
What does the input tab say?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
here is a picture from the summary and the input tap.
Not enough information.  You should open a TAC case so they can see your information unredacted.
Look at the service that is produced, Click on summary and compare the service rules to your incoming authentication.  Something is not matching, is why the input is not matching a service.
now I used an other service tempate an I got an accept, but the captive portal shows an authentication error an I cannot surf in the web.
What can I do to get this up an running?
Please take a look on the photos.
Thanks @ all
it is not obvious from what you have there.  There could be a problem with your weblogin page on the ClearPass guest side.  You should open a TAC case so that they can look at all parts of your configuration.
ok, thanks
Occasional Contributor I
Do you have any update from TAC? I have the same behavior.
