IAP RadSec with Clearpass
I installed an external portal solution with IAPs and a CPPM. Everything is working fine so far, but I would like to chance the communication from RADIUS to RadSec. The reason for this is, that the IAPs are at a remote site and the cppm is placed in our Datacenter. The communication is via WAN and without an extra encryption (like IPSec).
The IAP support RadSec (which is the method used i.e. with the central cloud guest portal), but the clearpass does not. So I think I have to use a RADIUS Proxy in the datacenter which supports RadSec.
Has anyone already tested a similar solution? Did you use freeradius or radsecproxy? Did you test the radius proxy communication with the external portal configuration or is it exclusively for WPA2-Enterprise authentication?
Btw.: I don't see a way to configure the radsec on IAPs with aruba central, but that's another topic.
