Regular Contributor II
IAP vlan for MGMT and for traffic
Hi All,
Is it possible with IAP´s to have different Vlans for MGMT and for traffic, similar to the ones that we can have in a Controller?
Like this example:
port 1/0 vlan 1 MGMT 172.25.1.100 , Gw 172.25.1.254 – MGMT network
port 1/1 vlan 99 192.168.122.254 /24 , gw 192.68.120.1– network for  Ap´s e Controller
port 1/2 vlan 4 DMZ internet 192.168.120.73 – connects to a FW Linux
Regards
Re: IAP vlan for MGMT and for traffic
The management network will be the same as the AP network. You can add additional VLANs for user traffic.
Tim
Tim Cappalli | Aruba Security
absolutly, you can.
as alredy Said the the AP VLAN is the Management VLAN , you can edit it "by AP " in the AP menu uplink  angle.
and also you can associate Vlans by ssid .
take just in mind that the default native VLAN for Aruba IAP is "1" , and you can change wired parameters in "wired profile"
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
