Identifying Hypervisor
TBH I havent looked very hard, but is there a way to identify from the ClearPass interface which hyperviosr has been used? ie ESX, Hyper-V, Bare Metal?
I know you can look at the hypervisor console, I dont always get access to this...
Re: Identifying Hypervisor
I gues in answering my own question, for ESXi at least, you could go to the Endpoints repo and find the CPM host. The Vendor MAC should say VMWARE etc.
Is that the only/best way?
