Frequent Contributor I
Implementation question - blocking end-point vendors
we are interested in blocking ALL smartphones from our wifi solution.
What I have done is the following:
I have added the following under services-->enfo.
This is working now and blocked Samsung S3 and apple devices.
Is this a good way to implement or should I use profiler or a different option, I have full clearpass license.
Any suggestions will be gladly appreciated.
3.(Connection:Client-Mac-Vendor EQUALS Murata Manufacturing Co., Ltd.)[Deny Access Profile]
4.(Connection:Client-Mac-Vendor EQUALS Apple, Inc.)
Trusted Contributor I
Re: Implementation question - blocking end-point vendors
see the question i asked in your other thread.
personally i would go with ClearPass profile if you can. It gives more granularity, i.e. differentiate between iPads and iPhones i believe.
In Role Mapping, try this:
Authorization:Endpoints Repository Category Equals SmartDevice
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
i tried it but it dosent seem to work.
if i goto identity --> end point i can see my client mac address with profiled no status unknown.
Do you have a helper address on your wireless subnet pointing to cppm so your devices can be profiled?
i also tried this role but still i can authenticate and connect
(Authorization:[Endpoints Repository]:Device Name CONTAINS Android)Block_Devices
Your endpoints repository only has basic information about your devices.  To get more information, you need to put an additional helper address on your wireless subnet to point to CPPM to collect that additional information and insert it into the Endpoints repository.  It will then be able to better classify those devices with more parameters, rather than just by mac address.
can you elaboratre on "To get more information, you need to put an additional helper address on your wireless subnet to point to CPPM to collect that additional information and insert it into the Endpoints repository"
what are the steps? is there a manual for this?
Do you have the profiler license? If you do, please search the user guide for profiler to ensure it is enabled.
If you do not, ignore what I said.
profiler is enabled as evaluation license in the product.
but the endpoint mapping is empty my phone was not categorized not profiled or detected as android. While other pcs are listed OK in the endpoints list.
