Contributor I
Import Devices to Clearpass Guest Device Repository
Hi All
We currently use a static host list to MAC auth some clients, but I would like to make use of the Clearpass guest device repository instead. Can anyone tell me if there is a way to import devices in bulk, I can see that it is possible to import user accounts from a CSV etc. but can't see a way to do this for devices.
Dave
Re: Import Devices to Clearpass Guest Device Repository
Yes, if you go to Manage Devices > More Options > Export Guest Accounts and
then CSV, take a look at the file for the format. (Be sure you have at least
one device already in the database)
Tim Cappalli | Aruba Security
Make the sure the CSV contains the attribute mac_auth and that the value is 1. For example:
Full Name,Account Role,MAC Address,mac_auth
Client1,CLIENT-VLAN,aa-aa-aa-aa-aa-aa,1
Client2,CLIENT-VLAN,bb-bb-bb-bb-bb-bb,1
Printer1,PRINTER-VLAN,cc-cc-cc-cc-cc-cc,1
See the guest userguide page 77:
https://community.arubanetworks.com/aruba/attachments/aruba/SoftwareUserReferenceGuides/29/1/ClearPass_Guest_6.4_User_Guide.pdf
Dennis Lansink • Security Engineer
Securelink Nederland
Contributor II
I would like to know whether doing this will consume any guest licenses?
Thanks.
No.
Contributor II
Thanks, is there any limit on the number of guest account that be created on the repository?
Nope!
