I have done that for some of our older CiscoIP Phones that do not support 802.1X. Tou need to import the mac addresses as Endpoints or use the API. If you are doing a list, the XML import is probably easier. Be careful, though. I found the XML tricky when importing multiple Endpoints. They looked OK in Endpoints, but my service would not key on the attribute I was using. I assume you have a MAC Auth service, etc. set up.
Here is a sample XML format from CPPM 5.1.1.
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<TipsContents xmlns="http://www.avendasys.com/tipsapiDefs/1.0">
<TipsHeader exportTime="Fri Sep 28 10:50:24 EDT 2012" version="5.1"/>
<Endpoints>
<Endpoint macAddress="00112032b378" status="Known">
<EndpointTags tagName="Device Type" tagValue="Cisco IP Phone"/>
</Endpoint>
<Endpoint macAddress="001120f67643" status="Known">
</Endpoint>
</Endpoints>
<TagDictionaries>
<TagDictionary allowMultiple="true" mandatory="false" dataType="String" attributeName="Device Type" entityName="Endpoint"/>
</TagDictionaries>
</TipsContents>
I believe you need Unix line endings in the XML file.
I hope this helps.
