Contributor II
InCommon Certificate Problem
I've generated a CSR and private key file from my ClearPass.
I've used that CSR to get a certificate from my provider - InCommon.
When trying to import that certificate and the private key, I get the message:
Private Key File does not match the Certificate
Either I am doing something wrong, or there is something wrong with this certificate I am being issued (I've tried more than once)
Thanks for any help.
Re: InCommon Certificate Problem
Compare the public and private keys using openssl to ensure they are a match.
It's also generally recommended to do your CSR and key generation offline.
Tim Cappalli | Aruba Security
Contributor II
Creating them using openssl did the trick.
Thanks!
