Insight Scheduled Reporting - CSV required
Greetings,
We have set up automated reports from within Clearpass Insight which emails the report to nominated users which works as expected.
The report appears as a PDF attachment, which for one of the reports (goes to management) is fine, however we need to perform a small change to one of the reports which isnt possible to manipulate with a PDF.
If we run the report manually, we get presented with the options for PDF, CSV or HTML, but automating this shows PDF only.
Is there any way to change the automated file type to CSV
TIA
Gordie
