Frequent Contributor II
Insight and TACACS
Hi All,
I am able to generate reports for TACACS,
But that reports contains all the the coomands (ex- show). I want to see only change command.
Is there a way I can generate reports for only change command ?
Also I am getting reports in PDF format, How to change it to CSV or HTML ?
rana
