Regular Contributor I
Insight reports showing statistics
For one of my customers, I would like to do a Insight reports that display a count of all authentications and a chart like Device Category in the Dashboard, is it possible ? What I like to show him is the number of connection and the type of devices used for this service but with not too much details.
Dimitri
Re: Insight reports showing statistics
Have you tried using Analysis and Trending in Clearpass under Monitoring...might be what you're looking for.  Also, you can create custom filters as well to do a line or bar type graph.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Remember on Insight if you create a report, you select the information on the top that you want a graph on.
Thank You,
Troy
Thank you Troy, I'll try and give a feedback.
Dimitri
