Frequent Contributor II
Insight reports
Anyone doing insight reports? We run CPPM 6.2.0 and I tried making reports but they always fail. Trying to make report off of radius authentications.
Re: Insight reports
What are your exact steps?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Re: Insight reports
I search and then I select Create Report and I changed the USER to the user who i want to create the report on.  I save the report and then run the report.Switch.PNG
Re: Insight reports
Is there an error message?  Does it just keep on spinning?  What happens?
Re: Insight reports
Are you seeing data in the dashboard of Insight?
Thank You,
Troy
Re: Insight reports
yes, I can see normal graphs and I can perform seaches but just not have it "generate" reports
