Super Contributor I
Installing certs on a mobility controller
I've  installed a cert and some CAs on one of our mobility controllers a while back  and looking at the certs config on the controller  I've got
aruba0_080713.txtServerCertaruba0.pkcs122No
AdTrustExternalRootTrustedCAAddTrustExternalCARoot.crt1No
TerensslCaIntermediateCATERENASSLCA.crt0No
UTNIntermedIntermediateCAUTNAddTrustServer_CA.crt0No
Looking at the Server cert I can see that the issuer is TERENA SSL CA and you can work your way up the CA chain. Why doesn't the controller say that Terena ssl ca is referenced in the Server Cert, that UTNAdd in Terena?
Rgds
Alex
Aruba
Re: Installing certs on a mobility controller
The reference is if it is used in the configuration somewhere.
ACCP, ACMP, ACMX #294
mclarke@arubanetworks.com
