Frequent Contributor II
Instant clusters to Aruba controller IPSEC tunnels
hello Airheads,
we have a customer who wants to roll out Instant clusters to their retail stores (between 3 and 10 IAP's per store).
They would like to push their guests down IPSEC tunnels from the cluster and terminate on a centrally located
Aruba controllers (3600's). Question is how many IPSEC tunnels can the 3600 terminate from an Instant cluster
(terminating on the VIP of the cluster)?
cheers
Pete
Valued Contributor I
Re: Instant clusters to Aruba controller IPSEC tunnels
I know this isn't what you asked, but wouldn't it be easier for you/them to use RAPs? Or rather a good indoor AP model in RAP mode?
Granted you'd need the controller licenses, but the result would be slicker?
Kudos appreciated, but I'm not hunting! (ACMX 104)
Absolutely my friend.
We are proposing two solutions.
1. RAP's to Aruba controllers.
2. Instant clusters to Aruba controllers
Like you we prefer the first solution but as cost (as always) may become an issue we are intending to propose solution 2 as well.
cheers
Pete
Pete_Elms,
The second solution is by far the most flexible and resilient.  Any access points that you want to deploy with solution 1, has an IAP equivalent in solution 2.  In addition, the IAP-VPN setup only requires one VPN tunnel per site back to the controller vs. Remote APs, which require an IPSEC tunnel for each access point.
To answer your initial question, please see the document here:  http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Content/ArubaFrameStyles/IAP%20VPN%20Support/Overview.htm
That's our feeling as well.
Appreciate the feedback.
thanks Pete
I personally would want the RAP solution. But that's just personal preference.
Michael_Clarke,
Please say why you prefer it so that Pete can make an informed decision.
CJ, I guess you mean me and not MC? Can't see a post from him.
It's a bit like plumbing isn't it really? Personal preference. All things being fairly equal to the customer of course?
Happy to be challenged, but I guess my initial thoughts are...
1. RAPs tend to be a bit easier to tear up/down/reset in my experience when troubleshooting(retail tends to move around a bit).
2. Split tunnel options with RAPs (maybe we can do this now on instants?).
3. No Airwave or other monitoring was mentioned. So with RAPs, operational state is a bit clearer?
4. 3G backup options with RAPs.
5. More granular easier administrative revoking of RAPs that get stolen?
That sort of thing. Am I wrong?
The racking money,
Yes I do mean you, sorry.
1.  Good Point
2.  Instants do have traffic and DNS split tunnel options
3.  You can monitor users and IAPS with Airwave
4.  You can use 3g/4g backup with instants that have a USB port for that purpose
5.  You can certainly revoke an instant's mac address.
Please stay tuned for an IAP-VPN configuration guide that is coming out shortly.
MVP
I've been messing with iAP to Controller tunnelling and so far:
1. I can't speak to this, never used a RAP
2. Splitting is easy enough, the documentation doesn't quite match what I see, but it works fine.
3. Again can't speak to RAPs, but with and without Airwave the iAP operational state is pretty east to tell, just a different method from controller based connections.
4. I believe there are iAP with 3G and 4G backup methods - given all the setup pages for it in the GUI (I haven't got those models)
5. Revocation of the iAP is easy at the Virtual Controller (cluster membership) and at the Controller (VPN/Tunnel connection).
It's probably much more a matter of familiartiy than of technology at this stage. Do what's comfortable if it delivers everything you need, start heading up the learning curve if you need more/different functionality.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
