Integrate Cisco WISM2 and Clearpass Guest
I'm new to clearpass guest and with some help from airheads and some other users I have one of my K-12 buildings up and running using Aruba AP's and Clearpass guest with my new 7210 controller.
However my remaining four buildings are all still on Cisco AP's with a Cisco Wism.  I'd like to bring up a guest SSID on the cisco equipment and have it use Clearpass guest in order to have guest and students/faculty/staff authenticate or request accounts just like they do now in my new deployment.
I found directions in airheards but I'm not sure if I can have both Aruba and Cisco using the same Guest Setup or not.  Help!  Thanks in advance!
Contributor II
Re: Integrate Cisco WISM2 and Clearpass Guest
You have to create a different one for Cisco. Under NAS Login settings, vendor setting should be Cisco:
Below link may help you:
https://community.arubanetworks.com/t5/Security/Clear-Pass-integrate-with-Cisco-WLC/td-p/142741
Jibran Aziz
ACDX / ACCP / ACMP / ACMA / CCIE (RnS, SP, DC) / JNCIS / JNCIA
