Occasional Contributor I
Integration Aruba Amigopod (ClearPass Guest) with other vendors
Hi, does anyone know, if ClearPass Guest is able to integration with Cisco and Ubiquiti.
Frequent Contributor I
Re: Integration Aruba Amigopod (ClearPass Guest) with other vendors
Cisco - yes. Ubiquity - it is good question - in CPPM/GM you have drop-down list with all predefined vendors in NAS/Web Login configuration.
HTH
Marek Krauze, CWNE# 174, ACMX #295, ACDX #356
Something cool, helpful or interesting in my post - click the Kudos Star.
Helped to solve your problem - Click Accept as Solution
As I understood, ClearPass Policy Manager can be integrated with:
3com
3GPP
3GPP2
Acc
Acme
ADSL-Forum
Aerohive
Airespace
Alcatel
Alcatel-Lucent-Service-Router
Alteon
Alvarion
APC
Aruba
Ascend
Avenda
Azaire
Bay-Networks
BinTec
CableLabs
Cabletron
ChilliSpot
Cisco
Cisco-BBSM
Cisco-VPN3000
Cisco-VPN5000
Clavister
Colubris
Cosine
Digium
Epygi
Ericsson
ERX
Extreme
Fortinet
Foundry
Freeswitch
Gandalf
Gemtek
H3C
HP
Huawei
IEA-Software
IETF
infonet
ipUnplugged
Issanni
ITK
JRadius
Juniper
KarlNet
Lancom
Livingston
Local-Web
Lucent
Manzara
Merit
Microsoft
Mikrotik
Navini
Netscreen
NetworkPhysics
Nexans
Nokia
Nomadix
Nortel
NTUA
Packeteer
Patton
Propel
Prosoft
Quiconnect
Quintum
Redback
RedCreek
Riverstone
Roaring-Penguin
Shasta
Shiva
Siemens
Slipstream
SofaWare
SonicWall
SpringTide
Starent
Symbol
Telebit
Trapeze
Tropos
T-Systems-Nova
Unix
USR
UTStarcom
ValemountNetworks
Versanet
Walabi
Waverider
Wichorus
WISPr
Xedia
And ClearPass Guest can be integrated with:
  • Aerohive
  • Alcatel-Lucent
  • Bluesocket
  • ChilliSpot
  • Cisco
  • Colubris
  • HP
  • Consentry Networks
  • Dell
  • Enterasys
  • Extreme Networks
  • Extricom
  • Juniper
  • Meraki
In the matter of fact you can integrate CPPM with any kind of 802.1x device, because you can add RADIUS dictionary. But you have to bear in mind that Guest is completely different thing - there is such kind of proper http parameter passing integration. So the list you just got from the GUI is quite accurate.
Many regards,
Marek
ok .Thank you.
If you think that my answers were helpful, please kudo/mark as solved.
Regards
You can add Ruckus to that list for Clearpass Guest.
ACCP, ACCX #817, ACMP, ACMX #294
Thanks mike. I will add it to our docs
Thank You,
Troy
Do all functions of Clearpass Guest integrate with Extricom?
I know Radius authetication does work with predefined accounts, but does it work properly with email or sms Registration, and does ist work with MAC Authentication for returning Guests?
Thanks, Rene
Hopefully someone in the community can speak up, in the past 5 years Ive been in the NAC field I have never came across them.
Looking at their docs it shows it has an interal captive portal but I couldnt find anything where it supports external, so you may not be able to use the self reg. You could only do CP auth from their software. You should be able to do MAC cacheing but I dont have any conformation for you.
Thank You,
Troy
