Interoperability between ClearPass and kpnqwest
Hi All,
does someone use kpnqwest as SMS-gateway on ClearPass?
Thanks and Best Regards
Re: Interoperability between ClearPass and kpnqwest
It looks like they have an API: http://www.kqi.it/en/Servizi/SMSGateway/ApiSms.aspx
So, you should be able to use the API and select Custom HTTP Handler for the SMS Gateway in ClearPass Guest.
Zach Jennings
