Occasional Contributor I
Interoperability of Aruba / Dell AP on same network
Can Aruba branded IAPS and Dell IAPS coexisit on the same network ? Meaning, if I have one AP as the master, and let's say I add 2 or 3 new IAPS (Dell branded), will the VC see them, manage, firmware upgrade them, etc as if they were Aruba branded ?
Or mis-match in firmware
Re: Interoperability of Aruba / Dell AP on same network
It is not supported and it is unpredictable.
Can the Dell IAPS be re-flashed with Aruba IAP firmware and then interopt. should be fine across the board ?
No.  This is not supported.
