Ip address issue for Vlan
i have one SSID profiel(Say X) if i was using X vlan i was getting proper address . if change Vlan to (say Y) we are getting different ip address .configuration of both Vlan matched .kindly help.
Re: Ip address issue for Vlan
Hi Siva,
We might need some additional info to see whats happening there.
 please get us,
show ap essid
show user-table ver |  incl <client-mac>
show user  ip  <ip-address of client>
show ip interface br
show ip dhcp database
Vinod Kumaar AVM ACMX, ACDX
Principal Network Engineer
Customer Advocacy | Aruba Networks Inc.
Did something you read in the Community solve a problem for you? If so, click "Accept as Solution" in the bottom right hand corner of the post.
