Is 802.11r supported in CPPM or NPS by default?
I see mentioned a few times that for dot11r, it needs to be supported by the radius server.  Just wondering if this is enabled out of the box for Clearpass, and if not where/how to enable?
Is it also the same for MS NPS?
ACCP, ACCX #817, ACMP, ACMX #294
Re: Is 802.11r supported in CPPM or NPS by default?
Michael_Clark,
Can you please point to the link where it says that 802.11r is dependent on the radius server?
It would seem I got my standards mixed up and posted in haste.
Apologies.....please ignore.
