Valued Contributor I
Is it normal to see a master publisher sitting at 100% swap memory usage
Our MP (5K VM) regularly sits at 100%. Reboot it and swap seem reasonable for a while then ts back up to 100%
A
Re: Is it normal to see a master publisher sitting at 100% swap memory usage
No. What's your memory usage and amount of memory?
Cheers
James
It's a standard 5K VM 8 CPUs 1 TB disk space and 8Gbytres RAM
According to VMWare its got 8Gbytes of memory and its using~4.5G
According to clearpass
Swap mem usage 100% Free swap mem 8Kb =Total swap mem 2.93Gb
Swap space used 3.0Gb swap space total 2.93Gb
Swap memory is (generally) used when a system is low on memory. As your VM doesn't appear to be low on memory I (personally) would log it with TAC.
Cheers
James
Seem to remember that I did this a while ago without much luck, but as
we're about to roll out a clearpass guest network that'll need guest
device registrations need to get it sorted.
As you said think another TAC call is in order
A
Apparently engineering know about this issue. Got a remote session tomorrow morning
The problem wss that we wee suffering from "Old VM" syndrome. our master published has been around for a long time and wa only configured with 3Gbytes of swap space. New VMs have 6bytes.
TAC remote session increased swap space to 65Gbytes
