Contributor II
Is it possible to bulk expire device accounts?
I have hundreds of devices that students self-registered in Clearpass Guest (mactrac) last year, and they have no expiration date set.  I have since learned to edit the form and set a default. :(
Is there any way to bulk expire these accounts?
Regular Contributor II
Re: Is it possible to bulk expire device accounts?
In version 6.5.2 there is a "Manage multiple accounts" option where you can select multiple accounts and click edit and then change the expire time for all the accounts.
David
ACDX #98 | ACMP | ACCP
Contributor II
Brilliant, thank you!
