Is it possible to use ActiveSync as an Authorization Source in ClearPass
I was wondering if anybody has used ActiveSync as an Authorization Source to allow access to mobile devices ?
There's an ActiveSync plugin that needs to be installed in the Exchange Server
But do I need to point ClearPass to the server using the Endpoint Context Server :
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Re: Use ActiveSync as an Authorization Source in ClearPass
The ActiveSync plugin is only used as another way to profile devices.  It is not used for authentication or authorization.
"ActiveSync Plugin
The ActiveSync plugin is provided by Aruba and is to be installed on Microsoft Exchange servers. When a device communicates with exchange server using active sync protocol, it provides attributes like device-type and user-agent. These attributes are collected by the plugin software and are sent to the CPPM profiler. Profiler uses dictionaries to derive profiles from these attributes. "
I was confused .....but now I get it..
Thanks CJ
Thank you
Victor Fabian
