Is there a signed installer for Aruba QuickConnect?
We have Clearpass deployed and using it successfully for mobile devices and BYOD.  On the WIndows devices, users are prompted to download ArubaQuickConnect.exe which comes down fine, but the browser reports "ArubaQuickConnect.exe is not commonly downloaded and could be dangerous." and then when executed User Account Control reports that the publisher is unknown.
I'm just trying to make things less confusing for my employees.  Is there a signed installer for QuickConnect?  We are on 6.2.6 right now.  I don't see any mention of it in the 6.3 release notes.
Thanks.
Re: Is there a signed installer for Aruba QuickConnect?
Not everyone has Aruba as a trusted profile sign and the apps settings change based on the settings you put in the provisioning profile, so we don’t sign the Windows app ourselves.
We give you the option to sign it with a trusted Root or internal since this is based on your internal settings.
Thank You,
Troy
