Occasional Contributor I
Issue of android 4.4.2 credential storage password
Hi, I'm facing an issue with the subjecct describe.
After install the QuickConnect, it need to download and install the Network Profile.
But it'll keep prompting the issue of key in the password for the credential storage.
Anyone have any solution to bypass this issue?
Re: Issue of android 4.4.2 credential storage password
In older versions you have to type 1234 for the password.
Thank You,
Troy
Hi Troy,
even typing 1234 as password it'll show incorrect password
Regular Contributor I
I'm also having this issue, has anyone solved it?
It's not consistent, as we have some Samsung S5s with the same software that do work fine.
ACMA ACMP
