Issue with guest self-registration
Morning folks,
I'm trying to deploy a new guest self registration site and running into an, what i think is, an ldap/email issue.  Version is the latest,, with Cisco WLC.  Basic auth works fine with a login page and static accounts.  Self-reg without 'require sponsor confirmation' also works fine.  When I have 'require sponsor confirmation' enabled i have issues.
I added a sponsor_lookup field to the form used by the page and on the self-reg page i'm able to lookup people via AD.  However when i try to register i get an error 'This account could not be found.'  If I use the sponsor_email field instead of sponsor_lookup and manually enter an email address, it all works fine.
The ldap/email issue, i think, is this; under the attribue mapping on the AD server properties, i had to change sponsor_email from userPrincipalName to mail as in this schema userPrincipalName is mapped to an invalid email address.
Now this is a brand new deployment and also the first time i've used Clearpass so I might be missing something obvious here.  Anyone have ideas on this or is there a way to see what's generating the account could not be found error?  None of the monitoring pages generate anything when the error occurs.
