Contributor II
Issue with onboarding Android device
I am getting the following error after I enter the username and password in ClearPass QuickConnect when trying to onboard an Android device. I have no issues onboarding IOS devices.
There was an error in configuring your device. Cannot download Device credentials from Onboard server: Value <!DOCTYPE of type java.lang.String cannot be converted to JSONObject.
And I don't see any error messages in Access Tracker.
Any ideas?
Re: Issue with onboarding Android device
Are there any errors in the application log on the guest side? (I doubt there are but just wanted to make sure)
Home > Administration > Support > Application Log
Thank You,
Troy
Contributor II
Troy,
I don't see any errors under Application Log. They are all informational. I am trying to onboard both Samsung and Nexus tablets. Same result.
Also what is the make/model/firmware of the device?
Thank You,
Troy
Contributor II
Nexus 7, Android version 4.3, Model ME370T
Model Number: Samsung GT-N8013, Android version 4.1.2
Are you redirecting by IP or FQDN? Most of the time I see that error its a communication issue between the device and CPPM
couple things to check
1. url
2. firewall/Role settings
Thank You,
Troy
Contributor II
Troy,
I was using landing.php in my URL. Once I took it out, it worked like a charm.
Thank you very much for your help.
