Frequent Contributor II
It is possible to use the location-id to enable nearly devices share an apple TV with Instant AP?
can anyboody help me?
It is possible to use the location id to enable nearby devices share a apple TV with Instant AP?? or instant ap have this limitation ?
IAP (clearpass) .
Sorry for my english.
Best regards
Re: It is possible to use the location-id to enable nearly devices share an apple TV with Instant AP
Using Clearpass and Airgroup on the instant APs, this is possible.  Have you read the Airgroup docuementation?
http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/8478/Default.aspx
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Ok, thank you.
HI,
My question is :
Can you use de location-id when you add a device at airgroup?  (Instant AP)
i attached a image
