Juniper SRX and Clearpass as external captive portal
I'm trying to integrate juniper srx with captive portal on aruba clearpass but i can't find good documentation how to do this. Im redirecting users unauthenticated and unknown-users to clearpass web login page but i don't know how to push user credentials back into srx after captive portal authentication. Maybe someone done this scenario before?
Re: Juniper SRX and Clearpass as external captive portal
Interesting one ! Any updates on this ?
ACMP, ACCP, BCNE
Contributor I
I hope below url will helpfull for you
https://community.arubanetworks.com/t5/Security/NEW-TechNote-CPPM-amp-Juniper-SRX/td-p/263505
You need to add Juniper SRX as context server and then you need to enforce session notify enforcement (JUniper srx IP) profile to captive portal authenticated users. Clearpass will send notification to Juniper SRX about client device ip address, User Name, User Role, Domain,  Device Type, Machine OS.
Milind Y
