Juniper SSG and CPPM RADIUS/TACACS configuration help
This is the SSG Configuration
set auth-server "external" id 1
set auth-server "external" server-name "172.16.1.10"
set auth-server "external" account-type admin
set auth-server "external" type tacacs
set auth-server "external" tacacs secret "xxxxxx"
set auth-server "external" tacacs port 49
set admin auth server "external"
set admin auth remote root
set admin privilege get-external
I'm just not clear on how to create the enforcement profiles and policy..
thanks for the help!
Re: Juniper SSG and CPPM RADIUS/TACACS configuration help
I have attached the logged error screenshot and the enforcement screenshot.
I am facing the same issue. Has anyone able to solve this? What attributes should I put in the enforcement profile?
Aruba please help with this.
Thanks.
You should be able to follow similar steps in ClearPass:
https://kb.juniper.net/InfoCenter/index?page=content&id=KB23458&actp=search
Tim Cappalli | Aruba Security
I have tried to configure similarly but still unable to be done. There are some steps not available in aruba cppm from the cisco acs.
Can you provide the step by step guide with exact configurations for Juniper SSG and Aruba CPPM tacacs?
Aruba support please help and advise.
Thanks! :)
Any support or help from Aruba? Until now, I still can't get it to work.
Unfortunately we don't have an SSG to test with. Have you reached out to
your Aruba ClearPass partner?
Yea, they can't solve it too and asked us to go online and ask aruba directly so that is why I'm here. Can it support Juniper Netscreen services? Any dictionary for it?
