Occasional Contributor I
Juniper switch configuration for fallback vlan in case of dot1x authentication failed for wired user
What would be the configuration required on juniper switch in the scenario if wired user failed to authenticate by CP it should then move to a guest vlan. I already configured the service on CP and users are getting vlan enforcement profile (guest vlan)  after authentication failure.
