Regular Contributor I
Kindly assist me regarding Aruba Clearpass 6.3 !!!
Dear All,
I want to install Aruba Clear pass on operating system Windows Server 2008 .
 I have downloaded the Aruba clear pass 6.3, Anyone here who can assist  me from now onwards ?
Re: Kindly assist me regarding Aruba Clearpass !!!
ClearPass is currently only supported as a vmware virtual appliance. You need to deploy the OVA template in a VMWare ESXi environment.
Tim Cappalli | Aruba Security
Sir basically i have no idea how to install it..
Can you assist me step by step or is there any pdf document ?
Sir according to your last post , if i am not wrong i understand that intially i have to install a ESX/ESXI Server on VM and Clear pass ?
You need a VMWare ESXi host, yes.
Windows Server Hyper-V is not currently supported.
Thanks alot sir,
For futher queries i will post some more on same here..
