  • 1.  LOGIN WEB
    Posted Jun 13, 2017 12:08 PM
    Hi all.
    I have a strange sitation with my clearpass i don´t see the option for add a new login web for external captive protal authentication.
    I have another clearpass that show that option.
    I atach you a picture with the issue
    Does anyone know why?
  • 2.  RE: LOGIN WEB
    Posted Jun 13, 2017 12:10 PM
    What is your admin role?
    Also, try changing back to the default theme.
  • 3.  RE: LOGIN WEB
    Posted Jun 13, 2017 12:47 PM
    Hi, thank for your response.
    I login to clearpass by policy managed with admin/eTIPS123 (admin "Super Administrator" ) and then in dashboard i click ClearPass Guest
    How can i change the default theme?
  • 4.  RE: LOGIN WEB
    Posted Jun 14, 2017 03:45 AM
    web login pages are now below  Pages - Web Login Pages.
  • 5.  RE: LOGIN WEB
    Posted Jun 14, 2017 06:06 AM
    Hi
    We have link on top right corner in Home>Configuration>pages>Web Login page section if we use default Clearpass skin.
    Try change the skin to default and check the status naviagate to
    and enable ClearPass Guest Skin.
    Pavan
  • 6.  RE: LOGIN WEB
    Posted Jun 19, 2017 04:21 PM
    I'm assuming from your screenshots, you were using the "Galleria Skin."
    What version of ClearPass are you using?
    I've opened a bug ticket to address the issue, but the other advice to change the skin to "ClearPass Guest Skin" [for admins] is likely the near-term solution here.
