Leap Issue Second
HI All,
Regarding this
http://community.arubanetworks.com/aruba/attachments/aruba/unified-wired-wireless-access/49619/1/ARUBA-PFB-20150430_Leap_Second_Field_Bulletin_Rev-3.0511.pdf
In our enviroment we have 3 Masters Controllers and 23 local controllers. Should I proceed to disable the NTP of each of the controlling server before June 30 and re-activate the July 1 to avoid any abnormality? All controllers have AOS 6.3.1.8
What are the risks of not take the recommended actions?
Thanks in advanced.
Re: Leap Issue Second
To avoid any issue, yes, disable NTP.  What hardware models are you running?
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
We have differents models:
3200
600
650
7002
3400
But, no problem, we will to proceed to disable the NTP server according with aruba's recommendations.
Thanks a lot!
Blanca Nieto,
NTP servers are only defined on the master controllers and pushed to the locals when you save the configuration.  You would just need to remove the NTP servers on the 3 masters and save the configuration.
