Learn more about ClearPass Licensing
Well, ClearPass licensing is not the easiest thing to do and understand, or? :-)
Is there any document where I can learn and understand how licensing works in easy way especially that with "Enterprise licenses"?
Maybe there is a some Excel file which can calculate licenses for us?
Re: Learn more about ClearPass Licensing
Please look at this article :
http://community.arubanetworks.com/t5/Technology-Blog/A-simplified-look-at-ClearPass-Licensing/ba-p/249938
Enterprise licensing is pool module license which allows you to use any of the clearpass modules ( guest , onboard , onguard)
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect @WEI
