Contributor II
Licenses for CPPM-Guest
Hi, my question is about the licensing need it for a cluster of 2 servers. Active-Standby.
Do I need to buy licenses for each server.?
For example I have 500 endpoints for guest services.
Server 1 need 500 guest liceses, Server2needanother500guestlicenses? (Total1000Licences)
or the licenses are shared between them? (Total 500 Licenses) and when the failover occurs the licenses are transmitted to the backup server.
Thanks in advance.
Re: Licenses for CPPM-Guest
IF they are in a cluster the lic are shared between both CPPM
Troy Arnold
Systems Engineer - ClearPass Specialist
Thank You,
Troy
