Limit number of Users Authenticating Against Active Directory
If you may help me please, i have Aruba 7210 Controller, and my SSIDs Authentication is done against a Windows Active Directory NPS Service acting as a Radius Server.
can i limit the user account to only connect two times ? if he tries to connect from a third device, session should be rejected ?
Re: Limit number of Users Authenticating Against Active Directory
Windows NPS server does not give you the flexibility to limit this. You would need a radius server like clearpass to do what you just asked.
