Occasional Contributor I
Load Balance Clearpass Guest?
Anyone Successfully Load Balance the Guest Login Pages?  anyway to achieve this using DNS Records? or load balancer?
I understand that Guest account creation is not available if publisher is down but normally users who are logging in already have an account.
Re: Load Balance Clearpass Guest?
The registration page can only be used from the publisher. There is no way
to load balance this. Did you setup a VIP?
Tim Cappalli | Aruba Security
No I didn't  because of Layer3 Segregation.
anyone know of any alerting (free/low cost) tools to ensure that Clearpass webserver remains up and is responding to http requests?
You can use a load balance to make the URL always available but just keep in mind that only the active publisher can create/modify accounts. You should use the load balanced with auto publisher promotion.
PRTG has a free version of their NMS which includes a web server check sensor.
Tim
Moderator
The Guest Portal can be hosted on a Subscriber... the account creation howver MUST happen on the PUB.
All of this is covered in a alot of depth in two of my TechNotes.
Cluster TechNote and my Load-Balancing TechNote.
Best Regards
-d
ClearPass Product Manager
