Load balancing clearpass using a hardware loadbalancer
Has anyone had any success setting up load balancing clearpass radius using Citrix Netscaler?
Moderator
Re: Load balancing clearpass using a hardware loadbalancer
Greg,
We've not specifically looked at NetScaler [but your timing is good], but we are engaged with Citrix and are looking at multiple opportunity's where we have touch points in our products and frameworks, one of these is NetScaler.
Hopefully you have seen I have a published Technote the covers F5 BigIP.... in theory all of the key features exist in NetScaler.... basic SLB / HChecks / RADIUS 1812/1813 / HTTP / HTTPS  so it should just be a process to build and test.
That's the good news, the bad news is that its not a project I have on my radar in the short term [before Q1 2016].
HTH.
F5 TechNote here CPPM and F5 Load-Balancing TechNote v1.0.pdf
Best Regards
-d
ClearPass Product Manager
thanks Danny. We currently have LB setup for 1812 and 1813 using persistance = CLIENT.UDP.RADIUS.USERNAME with a method of TOKEN = CLIENT.UDP.RADIUS.USERNAME
has there been any update on the NetScaler guide similar to the F5 one for LB clear pass
thanks
