Location Based Services in Controller and AAA
I have a single SSID on my network and i want to offer LBS. How i can configure the LBS services based on AAA. I think that ap-group is the best option but the point is how my AAA will read ap-group attribute in order to decide which service should be allowed based on the ap-group. I need to know which AAA attribute will help to learn the ap-group in radius request?
Which AAA attribute i should use to get the ap-group information from controller in AAA request?
Re: Location Based Services in Controller and AAA
The AP group and AP name are both sent in the radius request. Which RADIUS server are you using?
Tim
Tim Cappalli | Aruba Security
Thanks for your kind reply,
As of now any AAA just consider as standered AAA server which can authenticate any radius request.
I agree we are sending both but i need to hit the policy based on ap-group. which attribute of aaa i should consider it.
We would need to know what kind of radius server you are using in order to help.
Tim
It is Accuries AAA
Ali Haider,
The radius attribute you are looking for is the Aruba-AP-Group attribute.  The Value is attribute Number 10 and Aruba is Vendor ID 14823.  Aruba sends the Ap-Group as a string value in authentication requests to the radius server.  If you can configure your radius server to identify that value, you might be able to accomplish what you want:
(Aruba7640-US) #show aaa radius-attributes | include Aruba
Aruba-Auth-SurvMethod             39     Integer      Aruba      14823
Aruba-Mdps-Max-Devices            18     Integer      Aruba      14823
Aruba-CPPM-Role                   23     String       Aruba      14823
Aruba-Mdps-Device-Version         21     String       Aruba      14823
Aruba-AirGroup-Shared-User        25     String       Aruba      14823
Aruba-Device-Type                 12     String       Aruba      14823
Aruba-Mdps-Device-Imei            16     String       Aruba      14823
Aruba-AP-Group                    10     String       Aruba      14823
Aruba-Named-User-Vlan             9      String       Aruba      14823
Aruba-Mdps-Device-Serial          22     String       Aruba      14823
Aruba-Mdps-Device-Name            19     String       Aruba      14823
Aruba-AS-User-Name                29     String       Aruba      14823
Aruba-AS-Credential-Hash          30     String       Aruba      14823
Aruba-Auth-Survivability          28     String       Aruba      14823
Aruba-Framed-IPv6-Address         11     String       Aruba      14823
Aruba-Priv-Admin-User             3      Integer      Aruba      14823
Aruba-AirGroup-Version            38     Integer      Aruba      14823
Aruba-WorkSpace-App-Name          31     String       Aruba      14823
Aruba-Template-User               8      String       Aruba      14823
Aruba-Location-Id                 6      String       Aruba      14823
Aruba-Mdps-Device-Profile         33     String       Aruba      14823
Aruba-AirGroup-Shared-Group       35     String       Aruba      14823
Aruba-AirGroup-User-Name          24     String       Aruba      14823
Aruba-Network-SSO-Token           37     String       Aruba      14823
Aruba-AirGroup-Shared-Role        26     String       Aruba      14823
Aruba-Mdps-Device-Iccid           17     String       Aruba      14823
Aruba-Port-Id                     7      String       Aruba      14823
Aruba-No-DHCP-Fingerprint         14     Integer      Aruba      14823
Aruba-Mdps-Provisioning-Settings  32     String       Aruba      14823
Aruba-Mdps-Device-Product         20     String       Aruba      14823
Aruba-User-Vlan                   2      Integer      Aruba      14823
Aruba-AirGroup-Device-Type        27     Integer      Aruba      14823
Aruba-User-Group                  36     String       Aruba      14823
Aruba-AP-IP-Address               34     IP Addr      Aruba      14823
Aruba-Mdps-Device-Udid            15     String       Aruba      14823
Aruba-Admin-Role                  4      String       Aruba      14823
Aruba-User-Role                   1      String       Aruba      14823
Aruba-Essid-Name                  5      String       Aruba      14823
