Locked Myself out of Guest Portal
I have locked myself out of the guest portal page of clearpass.  I changed the admin account to use the (null profile) which in turn booted me out and now im locked out.
I don't have any other accounts to get in.
Does anyonw know a way to reset those profiles from the CLI?
Frequent Contributor I
Re: Locked Myself out of Guest Portal
Not aware of a way to reset the profile other than a database reset.
You could edit your guest login service to use the local user repository, create a user in their with a specific role and use an enforcement profile to set the admin_privileges, e.g. admin_privileges = Super Administrator.
Any amount of Kudos will be greatly appreciated!!!
Contact Aruba TAC. They may be able to fix it from the shell.
Tim Cappalli | Aruba Security
@timcappalli | | ACMX #367 / ACCX #480
Hi All,
Ended up just reverting from a backup from the previous day.  All good =D
