Longer than 90 days?
Is there a way to create a guest wireless account to make it longer than 90 days?
Thank you
Bob
Re: Longer than 90 days?
If you are using an external policy server like Clearpass, yes...
Thanks Colin. Yes I am using clearpass, but when I try to make it longer than 90 days it says I cant.
  1. What page are you trying to do this on?  Screenshot, please..
Contributor II
Have you added the required expiration period in the 'modify expiration options' box in Guest > Config > Guest Manager ?
