Occasional Contributor I
Lost of conectivity after reboot ClearPass
I downloaded two software patch yesterday and I rebooted clearPass after installing it.
I have Ip connectivity to Virtual machine and It is started ( I can do SSH) but I don´t get to connect by html access.
I had disk space problems because this installation was done over 40 Gb, and I could see in the monitiring page that I had 9GB bussy, and 1Gb available over a total 10Gb.
I think the disk is completly full and this is the problem, but I don´t know if it is possible to fix it and how to do it.
Re: Lost of conectivity after reboot ClearPass
You have to give it some time after a reboot for the web ui to come back.
You can also restart the service in the cli.
Service restart cpass-admin-server
Tim Cappalli | Aruba Security
Ok, thank you.
By console, I don?t know credentials..
________________________________
Este mensaje y sus adjuntos se dirigen exclusivamente a su destinatario, puede contener informaci?n privilegiada o confidencial y es para uso exclusivo de la persona o entidad de destino. Si no es usted. el destinatario indicado, queda notificado de que la lectura, utilizaci?n, divulgaci?n y/o copia sin autorizaci?n puede estar prohibida en virtud de la legislaci?n vigente. Si ha recibido este mensaje por error, le rogamos que nos lo comunique inmediatamente por esta misma v?a y proceda a su destrucci?n.
The information contained in this transmission is privileged and confidential information intended only for the use of the individual or entity named above. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this transmission in error, do not read it. Please immediately reply to the sender that you have received this communication in error and then delete it.
Esta mensagem e seus anexos se dirigem exclusivamente ao seu destinat?rio, pode conter informa??o privilegiada ou confidencial e ? para uso exclusivo da pessoa ou entidade de destino. Se n?o ? vossa senhoria o destinat?rio indicado, fica notificado de que a leitura, utiliza??o, divulga??o e/ou c?pia sem autoriza??o pode estar proibida em virtude da legisla??o vigente. Se recebeu esta mensagem por erro, rogamos-lhe que nos o comunique imediatamente por esta mesma via e proceda a sua destrui??o
Moderator
Hi Raúl
If you're trying to access by ssh keep in mind that the username is "appadmin". And about the password, if you can't remember it, the default one might still be in use.
There's something I so on a similar situation. My CP had crashed due to lack of HDD and I found that when the ssh session was open i could access the web-ui. Don't ask me why but that's how it worked :)
Regards
Samuel Pérez
ACMP, ACCP, ACDX#100
If I answerd your question, please click on "Accept as Solution".
If you find this post useful, give me kudos for it ;)
