The following command is used to define what the MAC user’s password string will consist of:
• 5530g(config)#eapol multihost non-eap-pwd-fmt
ip-addr
mac-addr
port-number
The non-EAPOL password attribute on the RADIUS server can be a combination of the MAC
address, Switch IP, Unit and Port number. You can select one of the single items shown above or
a combination. For example, if you wish to configure non-EAP authentication with MAC address
and unit/port-number, enter the following command:
• 5530g(config)#eapol multihost non-eap-pwd-fmt mac-addr port-number
The default setting for the non-EAP password string is IpAddr.MACAddr.PortNumber. If
you do not wish to use this format, remove the default setting using the command ‘no
eapol multihost non-eap-pwd-fmt’. Thereafter, enter the non-EAP password format of
your liking.
