MACTrac device address auto-detect
Hey community,
I setup MACTrac for BYOD device registration. I have the MAC in the initial redirect URL, but after the user logs in, it is no longer there. I am looking for a way to retain that info or display the MAC on the login page so they can copy it for the Create Device page.
I've seen some posts about PHP or Java, but not really familiar with those and don't fully understand what needs to be used and where.
The simpler the better, we would prefer if it is filled in the Create Device page, but if we can display it on the login page, that would get us started.
Also, ClearPass 6.6 and Aruba Controllers
Thanks.
Michael Haring
ACMP, ACCP, BCNE, CCENT, Palo Alto ACE 7.0
