Im in the process of setting up a mobile provisioning profile for IOS devices that pushes users to a Aurba BYOD SSID performing EAP-TLS termination. The mobile profile downloads to the client fine but when the client connects to the BYOD ssid it fails to connect. I get the following message in the error logs and auth trace buffer
Nov 30 16:00:16 <localdb 133019> <ERRS> |localdb| User a4:67:06:2a:ab:71 was not found in the database
Nov 30 16:00:16 <localdb 133006> <ERRS> |localdb| User a4:67:06:2a:ab:71 Failed Authentication
Nov 30 16:02:34 <localdb 133019> <ERRS> |localdb| User a4:67:06:2a:ab:71 was not found in the database
Nov 30 16:02:34 <localdb 133006> <ERRS> |localdb| User a4:67:06:2a:ab:71 Failed Authentication
Nov 30 16:04:34 <localdb 133019> <ERRS> |localdb| User a4:67:06:2a:ab:71 was not found in the database
Nov 30 16:04:34 <localdb 133006> <ERRS> |localdb| User a4:67:06:2a:ab:71 Failed Authentication
Nov 30 16:09:26 <authmgr 132152> <ERRS> |authmgr| 802.1x termination is disabled user a4:67:06:2a:ab:71, profile default-psk
(LGWCAAAWMC02) #
(LGWCAAAWMC02) #
(LGWCAAAWMC02) #
(LGWCAAAWMC02) #show auth-tracebuf ?
count Show last count number of packets
failures Show only failures
mac Filter on a specific STA or AP
| Output Modifiers
<cr>
(LGWCAAAWMC02) #show auth-tracebuf failures
Auth Trace Buffer
Nov 30 16:00:16 m-auth resp * a4:67:06:2a:ab:71 d8:c7:c8:12:a2:49 - - failed
Nov 30 16:02:34 m-auth resp * a4:67:06:2a:ab:71 d8:c7:c8:12:a2:49 - - failed
Nov 30 16:04:33 m-auth resp * a4:67:06:2a:ab:71 d8:c7:c8:12:9f:c9 - - fail
