MDM Integration - Manage Engine
Does anybody know if ClearPass can integrate with Manage Engine via Rest API's or anything? I know nothing about this MDM solution.
Thanks.
Michael Haring
If my answer is helpful, a Kudos is always appreciated!
Re: MDM Integration - Manage Engine
To explain further, the actual solution is called "Desktop Central 10"
Michael Haring
We do not have an integration today. Do you know if they have a REST API?
Tim Cappalli | Aruba Security
Unfortunately I do not have any information on the MDM platform, but I will look to see if I can find that information out. I've come across a few people asking about that solution now, and it's one I've never really seen before.
Thanks.
Michael Haring
