Frequent Contributor I
MDM and MAM Solution
I have a customer requiring features of MDM and MAM for all popular devices (500 endpoints) and apps. Can anyone please guide me on the solution designing for this requirment? They explicitly mentioned MDM and MAM and not onboard/ongaurd/guest etc.
Please advise and help if we can provide them the solution?.
Its a very urgent inquiry so your earliest reaponse is highly appreciated.
Thanks.
Re: MDM and MAM Solution
You will need to contact your local Aruba Territory Manager or SE.
You can send me a Private message with your contact information and location and I can forward your request on.
Thank You,
Troy
Thank you for your response.
 We have contacted local Aruba Territory Manager and he is helping us out in this but just to save time i have to have a solution in hand max by this evet thats why trying to get quick response from this community.
Please share the details about licensing scheme for this solution and whether or not we can fulfill the requirements.
Thank you
This email is late, but ClearPass 6.2 contains MDM for iOS and WorkSpace (which is required for MAM). This first release only supports iOS but android MAM support is coming. Not sure that a shipping version was available when you needed it, but you should be able to evaluate the new software at this point. again, talk to your account manager.
